Radiator Gunk
Old May 27, 2007 | 04:08 PM
LT1Drew's Avatar
Default Radiator Gunk
Well today i think i gave my formula the first flush of its life. I washed out the reservior with a hose and this muddy lookin green **** came out. The radiator wouldnt drain all the way so i put a hose in it and it also blew out a **** load of the muddy lookin stuff. Well my car has been runnin hot and losing power and sputtering...maybe this is why its happening? Im puttin some water wetter in it right now and fillin it with pink, Ill let you know what happens.
Old May 27, 2007 | 04:14 PM
sscamarotx's Avatar
I had the same thing happen to my Z. The tank on the side of the radiator was all gunked up. I ended up buying a new radiator, which sucks spending that much Fixed the problem though.
Old May 27, 2007 | 10:27 PM
spee's Avatar
Dex-Cool + Green antifreeze = goo.
I've had some gunky stuff in my overflow tank, but luckily that hadn't been sucked into the cooling system.
Old May 27, 2007 | 10:54 PM
LT1Drew's Avatar
yea what really sucks is after all that work i only put the cap on vented and it blew off. While i was hosing off the coolant all of a sudden the engine shut off and i havent been able to start it for about 4 and a half hours now.
Old May 28, 2007 | 07:39 AM
Z28Roxy's Avatar
Flush out the block too. Pull the drain plugs on it or at least the water pump.
Also make sure you bleed it after you refill.
Old May 28, 2007 | 08:42 AM
Boodyrider's Avatar
Oh please. Buy and install a 5 dollar flush kit, and backflush well. Then use HD rad cleaner, then flush again through the flush kit.
No need to take the WP off... and you ought to know better than to wet down the front of an LT1, especially with the non-vented opti.
Old May 28, 2007 | 01:39 PM
97LT1's Avatar
I agree with the last post. Get a flush kit install it, and remove thermostat and put back together. Then flush your heart out.
If you really want to flush even more, then remove the knock sensor on the block
Old May 28, 2007 | 03:39 PM
LT1Drew's Avatar
Does the 94 formulas have a vented opti? Cause im trying to decide what the hell the problem is...im almost positive its the opti. I've givin it enough time to dry out. I think im just gonna break down and buy some msd wires, blaster cap, and opti.
Old May 28, 2007 | 08:16 PM
F8L LT1 Z28's Avatar
I use the green antifreeze and Purple Ice
