bolt on tunes
bolt on tunes
does anyone have a tune for a bolt on's car....
i have a 2000 pcm.
cai
ported tb
ls6 intake
28# injectors
long tubes
underdrive pulley
4.10s
160*F thermostat
does anyone have a tune. i have efilive if it helps. ive already tuned for the gears, 160*F, and injectors.
or should i just get a dyno tune?
i have a 2000 pcm.
cai
ported tb
ls6 intake
28# injectors
long tubes
underdrive pulley
4.10s
160*F thermostat
since you have efi live, why don't you just tune it yourself?? each car will be different, what you can simply do is adjust the VE table until your fuel trims level out at -4 to 0 at all the RPM and MAP ranges. then set your PE mode to say down low RPM 12.6 and up high 13.3 or so
leave MAF stock
if you want help with it i can help you. just pm me. if you can scan the car, and then are unsure of what to change things to, send me the scans and your current tune, and then i can change it for you and we can see how that goes
do you have a wideband??
leave MAF stock
