Will A LS1 T56 work with a LT1 ?
A friend of mine is looking to buy a LS1 T56 for his LT1 car. my question is, will the LT1 bellhousing/hydraulics work with it? I know on LS1 T56s, the slave cylinder is on the inside, and the bellhousing is different, because the bleeder/slave lines run thru on the driver's side, and im guessing that the bolt pattern to the motor would be differenet as well.
but the main question is, will the LS1 T56 work with a LT1 bellhousing on a LT1 engine with LT1 hydraulics? thanks all!!
-Ron
-Ron
