Kooks review
Kooks review
Well my Kooks headers are in. After waiting and waiting on the QTPs, then finally going with Kooks - I could not have been happier. I have had my F1 cam in the car for over a month and it was just dying with the stock manifolds on there. This evening when I started it up with open headers - man oh man - what a sweet sound.
Install was not to bad. the passenger side header goes in in about 2 minutes. The driver side is a little more complicated. The way that I got it in was to pull the alternator to access the motor mount bolt. Remove the motor mount bolt on the driver side. Jacked the motor up a bit. Then more or less stood the header on the collector and pushed it in. It was still a little tight, but it went in fine. After that everything else was a breeze. No problem what so ever accessing the spark plugs on either side. No problem tightening any of the header bolts. Oil filter has plenty of clearance and the ground clearance looks good. I haven't put the ypipe on yet as I ran short on time today, but ground clearance doesn't look like its going to be a problem at all. I also have SLP subframes and it appears that there won't be a problem with the SLPs and the Kooks header/ypipe combo. I am really happy with the headers and delivery time was great - delivered 2 weeks to the day from when I ordered them.
Also - the kooks package is really nice. Came with 3'' wide band clamps that were a little different than any i've seen before - bigger diameter on half, smaller on the other half. Should really prevent any kind of leaks - pretty nice. Also came with new header gaskets and bolts. Oh and stickers..haha.
Re: Kooks review
Thanks. I asked because I have a set of Kooks with the RT Y pipe on order and it is about time for an oil change also. I figured if i had to take off the filter anyways, that would be a good time to change the oil too.
