wheel studs
Old 06-01-2007, 12:03 PM
gyrene2003's Avatar
Default wheel studs
ok, so made a similar post in the wheel and tire section, but to no avail, so im trying here. How do u change the wheel studs on the back axle, i know how to do it on the fronts but not on the back. from what i here its a bitch.
Old 06-01-2007, 01:00 PM
DuronClocker's Avatar
LS1Tech 10 Year
If you've got 4-channel ABS/TCS, you can pop out the sensors on each backing plate (held in with a single 10mm each I believe), and you should be able to get the studs out of the backing plate through that.
Old 06-01-2007, 03:54 PM
gyrene2003's Avatar
how do i know what channel i have, i do have abs and tcs?
Old 06-01-2007, 09:32 PM
Irocss85's Avatar
then you got 4 channel.
you talking puting in a stock stud, cause one is damaged? or wanting longer /aftermarket ones? if stock, you can just use a stack of washers, around 5 washers, and pop out the stud just like the front and use the lug nut/washers to draw the stud back in.
but, aftermarket studs (from my experience atleast) dont just pop back in place like a stock replacement stud. they should be pressed in with a hyd. press. which means you gotta take the axle out of the car to have them replaced.
