LM-1 programming with EFILive V2
Question concerning the LM-1 programing with the Boschs WB02 sensor. The LM-1 comes with software where I can adjust the output voltage scale. What is the best configuration? I'm running an 11:1 CR pump gas motor and plan on tuning idle-WOT. Since EFILive V2 will accept a 5 volt signal, would anyone recommend a scale up to 5 volts? I was thinking 1 volt at 10:1 AFR and 4.5V at 22:1 AFR. Does this increase the resolution into EFILive? Is this necessary to configure it differently than its defaults?
I set mine up to read 18.0 = 5 volts and 10.0 = 0 volts.
You dont have to change it, however, I am not familiar with how to set up EFI live to read it preoprly in terms of Air/Fuel.
