replacing turn signal lever
Hey guys Im looking at a 94 Camaro LT1 6 speed. The only problem with it is the turn signal lever/stick is broken. How hard is it to replace? Do I have to remove the steering wheel? Can it be done by myself easily?
What part is broken? The lever or the part the lever goes into. If it just the lever, it just pulls out with a light pulling and twisting back and forth. If the other part is broken, you need to pull the wheel off to replace. It's a big PITA.
Chris
Chris
