Sponsored by: DashLynx
gear shift indicator light removial
Old 06-03-2007, 04:42 PM
1lt1wiz's Avatar
Exclamation gear shift indicator light removial
how to remove the gear shift indicator light
Old 06-03-2007, 04:49 PM
Brian2006's Avatar
Put shifter in first gear. Remove the metal pin out of the front of your shift **** with a flathead or some sort of pliars. Remove shift ****. Open your center console, take out the change box, remove the two 7mm screws. Pop the console lid off starting from the back and then the front. Twist and pull out shift indicator light.
Old 06-03-2007, 04:52 PM
1lt1wiz's Avatar
Default light
is there a way to make the light blue
Old 06-03-2007, 04:59 PM
Brian2006's Avatar
Yep. Just buy a #73/74 blue LED
Old 06-03-2007, 05:06 PM
1lt1wiz's Avatar
Default bulb
would u happen to know where i could buy one of those?
Old 06-08-2007, 01:11 AM
Havok2's Avatar
1lt1wiz: pm brian2006, he knows where to get them.
Quick Reply: gear shift indicator light removial
