If have Leds inside / outside of your car come on in
Well i searched & came up with ery little ifno.
Anyone have a right up on how to pick the correct led ? I want to replace the side markers parking/turn signal / tail lamp Rr brakelight o start. i have not been able to find the part nubber for the leds,or how many I will need.
Can someone do a write up & sticky it.
pm me with any new info
Thx
Rik
Thx
Rik
PM sent, but as I said, everything is as easy as replacing a burnt out lamp with the only exception being the thermal flashers being a little tough to find under the dash. Look up what lamps you have on sylvania.com and then you will know which part number you need. From there, its a matter of choosing the right LED style to where it is going. The tower style LEDs work great in our tail light and front turn signal housings for a little bit of info.
-Brian
-Brian
