Exhaust Leak...
Old 06-05-2007, 03:23 PM
1BadTA13's Avatar
Default Exhaust Leak...
did heads/cam and threw on some pacesetter LT's and everythning is perfect except an exhaust leak on the right header....i cranked them bolts in about as far as i can get em and it still leaks....any solutions?
Old 06-06-2007, 04:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Did you use the gaskets that came with the pacesetters? If you did I would advise getting some stock MLS replacements.
Old 06-06-2007, 03:34 PM
tylerdj's Avatar
if you used the crappy pacesetter gasket I would pull it out and swap it with a metal OEM one....I had this same problem when I installed my Pacesetters.
