what would cause this?
Old 06-05-2007, 03:58 PM
Blown Ta's Avatar
Question what would cause this?
i got a wierd problem with my car, when the engine temp
goes over 210* the rpm go up to 2k on idle and drive. noticed
it whil sitting at a light. when the temp drops everything goes back to normal.
Old 06-05-2007, 05:08 PM
P Mack's Avatar
It almost sounds like someone changed your cooling fan airflow values way too high. If you open your hood and watch when it happens, does it happen when your fan comes on and stop when the fan turns off? If you had a scan program you could see what is changing with your airflow adders and figure it out real easy.
Old 06-05-2007, 06:51 PM
Blown Ta's Avatar
while the rpm's were high the fans are on, my fans are on at 180*.
and usaully stay on all the time.
i have hptunners but not sure what to look at.
Old 06-05-2007, 07:47 PM
P Mack's Avatar
Go to your table display in the scanner and add all the values that have to do with idle airflows. IAC position, Idle base PN airflow, idle cracker airflow, idle desired airflow, idle desired rpm, idle fans airflow, idle follower airflow, idle park position airflow, and idle AC airflow. You should see your IAC position jump when your idle jumps. You need to log all these when it happens to figure out which airflow adder is making the IAC jump. Before you do any scanning check and see in VCM editor that your engine>idle>idle airflow>cooling fan airflow values are .1 and .2.
Old 06-05-2007, 08:44 PM
Blown Ta's Avatar
ok, ill check those.
thanks
