ignition lock cylinder
Old 06-06-2007, 11:12 AM
Speed's Avatar
Default ignition lock cylinder
Hey all, have a quick question. I picked up a little v6 car for a project car but the owners have lost the keys. I went to the dealership yesterday and had a new set cut but the ignition key did not work. Door key worked great. I need to get the steering wheel unlocked so I can load the car on a trailer and get it home. I'm wanting to know if I simply removing the ignition lock cylinder, can I turn the steering wheel? I'm not worried about the car starting, I just need to be able to steer it.
Thanks for any advice you can give!
Old 06-06-2007, 08:20 PM
bowtieboy10's Avatar
to remove the ignition lock cylinder u will need to pull the stering wheel off, so that u can pull the bolt out so u can slide the cylinder out and u should be able to start it with out it. unless the secerty goes off. but yeah u will have to pull the wheel to get the cylinder out.
Old 06-07-2007, 03:37 PM
VIPERXAVIER's Avatar
Default Dealer cut keys
befor you go that far put the new key in the car and tap on it with something.
last saterday I had to get a new key made for my TA the key they made me worked but not till after I got a new switch installed.......
