Cadillac and LS7 lifters...weight
I don't know the answer, but I will tell you that lifter weight is unimportant.
If you want to help high rpm valvetrain stability via weight, do it on the valve side. The pushrod side should be focused on rigidity regardless of weight. (within reason)
