Textralia ?'s
Textralia ?'s
Im gonna buy a textralia clutch tomorrow prolly. I plan to hit 550-600rwhp one day. I know they rate off torque but should i go with the single disc x grip or should i just spend the extra little bit and get an exoskel twin now? Also what for slave cylinders is everyone using?
The Z grip is stronger, and although rated at 700lbfts, it will handle more.
But the X-grip will be more than adequate for you, and be nicer to drive...
Although the Z-grip drives pretty much like stock too.
Depends what sort of daily use you see......what sort of traffic situations etc
Im not worried about the pedal effort. I dont drive it much and if i do its not a big deal to me. I just wnat to make sure clutch is there when i start adding power. I also been thinking of adding a 50-75 shot on it to. Exo skel would be overkill yes but i wont ever kill it tho but i prolly will end up with a z-grip.
Pedal effort is no big deal IMO
How the clutch bites and drives is. But if it isnt a daily driver, and you dont see traffic situations, then it is of little importance.
Your requirements sound similar to mine. Currently full bolt ons, but cam will be installed in 2 weeks. I also made sure they knew that I was planning a Shot of spray up to 200HP. I was told the Single OZ700 would be plenty and the X grip would hold up fine and be very drivable in traffic and what not. Also I was told that if for some reason I do overpower the X grip disc, they will hook me up with a Z-grip. So I went ahead and got the Billet steel flywheel, OZ700 with the X grip. This clutch will be installed Tuesday night and I will report back with my thoughts on it.
