Check Out My Rack!!!?????
Old 06-09-2007, 10:51 PM
hothugger99's Avatar
Question Check Out My Rack!!!?????
Gotcha!! ....I have been noticing my rack has started to leak a little a few months ago. I just let it slide foolishly, but now I have about three inches left and right of top dead center of the steering wheel with movement before I have friction to turn the wheel. Basically, I can be going in a straight line, and be able to move the steering wheel freely back and forth without causing the car to turn. Is there any way to fix this without having to replace the rack??????????????????????PLEASE HELP...It now goes through a pint of power steering fluid a week.
Thanks,,,,,Loyal LS1Techies
Old 06-11-2007, 08:53 AM
NOBR8KSS's Avatar
Where is it leaking from?...if it is a loose fluid line connection, you may be able to just snug it down...if it is an internal seal on the rack, then you will need to replace it.
