Trac,ABS Inop, Brake ????????????
Old 06-09-2007, 11:02 PM
hothugger99's Avatar
Question Trac,ABS Inop, Brake ????????????
I have a right-front wheel speed sensor that went out on my Z. I don't have the time to get out there and change it right now, but those dang idiot lights are annoying. Is there any way to trick the system into thinking that theres nothing wrong with the wheel speed sensor, like when you install a transistor or capacitor to trick the skip-shift and O2 sensors??????!!!!!!!!????????!!!!!!!
Old 06-14-2007, 03:11 PM
Anyone??!!??!!??!!??!!??!!
Old 06-14-2007, 03:35 PM
rd_ls1_z's Avatar
I wish I knew. My rear sensor is out, had to by a new one to hopefully fix it. Did you have the dealer check the code? If not, what did you use?
