How does the PCM determin a misfire?
Old 06-10-2007, 03:25 PM
Senior Member
Country Boy's Avatar
Default How does the PCM determin a misfire?
What does the computer scan to determin a misfire condition and on what cylinder?
Old 06-10-2007, 09:21 PM
squealingtires's Avatar
Also, what constitues a misfire condition...no burn, partial burn, etc.
Old 06-13-2007, 09:40 PM
rnl35thss's Avatar
If I remember correctly, The PCM watches for timing fluctuations between the cam and crank sensors.
Old 06-14-2007, 09:40 AM
I have a #6 cylinder misfire that I can't figure out at idle (goes away above 1,200RPM), changed plugs, wires to no affect. It could be the coil but who cares? Anyways, just for fun I disconnected the wire on cylinder #5 and and the PCM was counting misfires on #5 as well as #4. Food for thought
Old 06-14-2007, 09:42 AM
LS1curious's Avatar
It looks at the speed of the trigger wheel. Based on variations in the speed of the wheel on the crankshaft it determines if it has a missfire. it looks for oscilation in the pattern.
