Camshaft sensor
Camshaft sensor
I have a 2006 A6 C6 and the check engine light came on, when i checked it, the code said it was a camshaft sensor fault. I replaced it and the light went off for a couple of hours and then came in again, when checked again it was the same sensor fault. Any one here knows why did it come back? Is there any need for a crank variation relearn after replacing the camshaft sensor? if yes, how can i do that ? And would it solve the problem for good?
