egr & air/smog removal ls1 edit?
does anyone know what codes to delete with ls1 edit for removal of the airpump system & egr system. im installing headers and not using these items. any help would be great. it is a 2000 z-28.
BADA BING BADA BOOM!!!!!!
Re: egr & air/smog removal ls1 edit?
Go into the Engine Diagnostic section and select Hardware Diagnostics. Then use the pull down menu and scroll down until you see the EGR and AIR pump codes. There are 5 for the EGR and 3 forthe AIR pump. Just toggle all of the codes to "Type x = turned off" on all of the EGR and AIR codes.
