looking for cheap lt1 parts!!!!!heads cam intake n2o ect ect
i'm looking for some good cheap parts for a lt1 build.i'm looking for heads, cams, intakes, nitros,rotating assemblies,forced industion parts,turbo system,supercharger, i am not sure what way i am going with this so just let me know what u got.trying to do this as cheap as possible.but will pay for good parts.
where are you located
i have a lt1 long block i would like to sell for $300. i am in south mississippi. it came out of a 95 z28 dont know miles, but it is the heads, cam, block, and rotateing asm.
383ci stroker: less than 7,000 miles.
Internally balanced, blueprinted, decked/Bored .030 over lt-1 block
ARP bolts/studs used where applicable
Eagle 4340 internally balanced crank
Eagle "h" beam connecting rods
Comp Cams high energy hydraulic lifters
Comp Cams 1.6 roller rocker
Comp Cams chromemoly pushrods
Cloyes double roller timing chain
Wiseco dish pistons/ring kit with floating wrist pins
Comp Cam custom 230/244 cam .580 lift w/114
lobe seperation
setup for roughly 10/10.5-1 compression
NGK TR-55 plugs
MSD 8.5 wires
New vented '95 opti spark
Mellings high volume oil pump
Intake
ported and polished lt-1 intake(to match heads and throttle body)
BBK 58mm throttle body
Throttle body coolant bypass
ported and polished lt-1 heads with Ferrea valves, guides, retainers
AFR Hydra rev kit
AERO adjustable fuel pressure regulator
EGR delete
Ford 30lb injectors
SLP CAI
Hooker headers
I'll do 5300, sell what you don't need. Comes with laptop and tuner, with a tune already loaded up. All wires and bolts. Motor is completely assembled and runs like a champ, it is currently my daily driver. Have dyno sheet as well. You said you would pay for good parts, well this is a good set up. No need to even get your hands dirty just do a motor swap! Very straight forward.
lobe seperation
NGK TR-55 plugs
MSD 8.5 wires
Intake
AFR Hydra rev kit
EGR delete
Ford 30lb injectors
SLP CAI
Hooker headers
