So is the 1LE swaybar HOLLOW or SOLID?
Old 06-17-2007, 08:25 PM
White_LightningZ's Avatar
Default So is the 1LE swaybar HOLLOW or SOLID?
and what is the stock 19mm? What is the weight difference?
Old 06-17-2007, 08:36 PM
vjo90rs8's Avatar
solid
I don't think anyone makes a 19mm hollow rear bar, that would not be much bar.
Old 06-17-2007, 08:45 PM
Originally Posted by vjo90rs8
solid
so the stock and 1le are both solid? seems right though since if the rear is solid the 1le should be as well. I had heard the rears were hollow though.
Old 06-18-2007, 11:15 AM
LS1TECH Sponsor
Sam Strano's Avatar
For these cars, all GM rears are solid, all GM fronts are hollow regardless of the size of "name" they have. A 19mm rear is the very same rear bar as a standard Z28 bar.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Quick Reply: So is the 1LE swaybar HOLLOW or SOLID?
