Help electrical problem
Old 06-18-2007, 08:18 AM
yak
yak's Avatar
Default Help electrical problem
So my car has an electrical issue where the battery will drain after a day or two. The wierd thing is that it will drain to about 5.25 volts and hold there. anyone have any ideas what could be the source of this?
Old 06-18-2007, 09:14 AM
greenherb's Avatar
do you have any after-market stuff in the car... amps alarm radar..... also with the car off hook up a DMM in series with one of the battery cables and set to read amperage,tell us that number, then pull your fuses one by one and see which fuse drops the current reading the most... that will be the circuit that has the most current draw and what ever devise is hooked to that is the most likely source of your drain
