Crane Cams 1.7 Gold Rockers question...
In the 144750-16 kit, what is the length of the pushrods that they come with? And, since I know they are shorter than stock (7.2 comes to mind, but someone remind me), isnt that drastically too low for the cars or does the rockers design call for a pushrod that short?
7.250 is correct. when you change over from a shaft/pedastal style mount over to a rocker stud set up, everything moves down closer to the head, so things get shortened accordingly, along with the way the crane has engineered the rocker arm geometry/rocker sweep pattern and preload will determine this length also.
