L92 Crank and Bottom End In an LQ9 Block?
Can I get the L92 Bottom End and put it in an LQ9 block? Id like to do that and SLP's L92 Top End Kit. I tried goin through the L92 info thread but couldnt find anything about it.
1 Post
No. Unless you want to waste alot of money. The L92 pistons are 4.065" wit floating pin. The LQ9's are 4.000" I think they've got press fit pins. The cranks are the same stroke and both are cast but all L92 cranks have a 58x exciter ring on them instead of the old 24x one.
