just bought corvette C5 front calipers $200 did i get a good deal?
Old 06-20-2007, 09:12 PM
ae13291's Avatar
Default just bought corvette C5 front calipers $200 did i get a good deal?
hi guys i just got front c5 brake calipers and brackets of a corvette for $200 i dont know if i got a good deal or not, and will these directly fit onto my crake system 99 camaro ls1 with the 16 inch rims thanks guys
Old 06-20-2007, 10:30 PM
Adrenaline_SS's Avatar
If you are using C5 front rotors, you will need C5 conversion brackets in order to properly fit the calipers. (UMI, LG, Trackbrackets and Kore3 are some companies who make them). You will also need 17" rims. I would not use C5 calipers on F-body rotors. They have a smaller piston, and would give you less braking force; giving you a rear brake bias.
P.S. You might have better luck with responses in the Suspension & Brakes section
Old 06-21-2007, 04:23 AM
WILWAXU's Avatar
Lets try this in the Brakes section.
