Drag Racing Tech
What should this setup run??
Old 05-06-2003, 09:25 PM
bodhi's Avatar
Default What should this setup run??
OK- check sig for setup. What size tire should I run? 26" or 28"- how would that effect et? My rev limiter is set @ 6600. Assuming full weight of Formula minus spare tire and backseat and a good lauch/ shifting.
My best run (w/stock 3.42's on nitto 555's) @ HRP was a 12.6 @ 118.6mph with a 2.26 60ft. (no traction) I am hoping for low 111's with the 4.30 gear and slicks- think it's possible?
'01 Formula- m6
JetHot Hooker LT's w/ORYP
Corsa Cat-back
ASP pulley
Katech ported TB
Comp Cams 228/224-.588/.581-112
918's
Ti retainers
Hardened PR's
MTI lid
SPEC stg III Ceramic
Pro 5.0 w/ LSS
Moser 12bolt w/ 4.30's
