L92/L76 Fuel discussions
What are you guys running for fuel injectors, fuel pump, and fuel pressures for your L92 setups. What % duty cycle are you seeing?
I have a 402 LS2+ L92/L76 setup with just a mild cam, with 42# SVO injectors. I have big fuel rails and aeromotive FPR.l
I have not started the engine yet. What fuel pressure should I be running?
Thanks
Thanks
im running a walbro 255 in tank, green tops with my little 370 and am seeing mid 60's at WOT. i have the proproducts fuel rails also. im at stock fuel pressure. why would you want to run at a differnt pressure than stock? 58 psi should be plenty with those 42lbs. you will prob be closer to 75% duty cycle max i would say.
