Startup issue
Startup issue
Every once in a while I go to start the TA and it doesnt crank. The battery seems charged as my lights work and radio etc.
But it just wont crank. So after like 4-5 tries and about 10 minutes it fires right up.
Starter?
Starter?
Could be the starter, but can also be a loose/corroded connection. there is also a safety switch on the clutch pedal IIRC. Might want to check it, make sure it didn't get out of alignment 1st.
