Bump Steer kit?? Alignment specs??
Old 06-24-2007, 06:11 PM
bluehawk2's Avatar
Default Bump Steer kit?? Alignment specs??
I am about to have an alignment done on the car and I was wondering if Baer is the only company that makes a good bump steer kit to solve the tramiling problem.
Also, should I get the alignment tech to use the factory specs or is there a special set of specs that will make the car handle a little better??
02 Firehawk with factory suspension
Thanks
Old 06-24-2007, 10:36 PM
Copy & Paste Moderator
VIP1's Avatar
Originally Posted by bluehawk2
alignment
Its in the sticky:
https://ls1tech.com/forums/showpost....38&postcount=3
Old 06-24-2007, 11:01 PM
bluehawk2's Avatar
Thank You
Quick Reply: Bump Steer kit?? Alignment specs??
