What Blew ???
Old 06-24-2007, 08:11 PM
stonie97's Avatar
Default What Blew ???
screwing around, went to hit second and wouldn't go in , now it will not go into second at all, grinds if you let out on the clutch and try to hold it in. bent shift fork, or synchro maybe????
Old 06-24-2007, 08:41 PM
Tech Fanatic
yellowbird1232's Avatar
The syncro struts are more than likely damaged. They keep the blocker ring and the syncro lined up.
Old 06-24-2007, 10:57 PM
wrencher
wrencher's Avatar
Or it physically broke 2nd, that does happen to them.
It really dont matter cause either way it has to come out & be tore down to find out
Old 06-25-2007, 11:33 AM
berger21's Avatar
Could be as simple as a shift fork pad. But it really dont matter cause either way it has to come out & be tore down to find out
Old 06-25-2007, 08:24 PM
ls1 joe's Avatar
Sounds like you broke the synchro teeth off the actual gear. We usually see at least 1 weekly like that. The old style 2nd gears are prone to issues. Upgrade to the new one and you will not have this issue again.
Amber
Old 06-26-2007, 03:18 PM
stonie97's Avatar
thanks for all the replys. If I get a chance this weekend , i'll have it out to see what it is.
