Pics of my 66 nova ls1 M6 C4 conversion.
It's been 3 years of a solo build, as the moneys made.
Plus the constant harrasment by **** neighbors.
It's been a tuff build.
I cannot wait to FIREITUP!!!!
http://itsaboutthecar.blogspot.com/
Originally Posted by nova65ss
Looks good, I like the gauges. How much longer until it's running?
Thanks,
Wiring and fuel system is all I left to make it run, also need to order the HPTUNERS,
Originally Posted by AmericanMuscle313
What Front clip are you using? What headers? Also was that an IRS in one of the pics?
Stainless works headers I had to severly modify these to fit, but they were a screamin deal off of ebay.
That IRS took alot of work and thought , just aiming the dog bones at what I'm calculating CG was a pain because then, when raising and removing the tires is impossible because the thing swings forward pressing the rear against the front of the wheel well. But I came up with an adjustable bolt that loosens from the cockpit that gives you just enough room to remove or install.
