78 t/a power windows question
Old 06-27-2007, 07:40 PM
blackdiesel's Avatar
Default 78 t/a power windows question
hey, i have a 79 trans am that i turned into a 78. I have shorted the power wire that goes to the power windows and i am just wondering if its a fuse or circut breaker? ive searched the fuse box and no blown fuses if its a CB, where is it located? thanks
Old 06-28-2007, 08:02 AM
EchoMirage's Avatar
i dont think there are breakers. just glass fuses by the e-brake pedal. are you sure it was the wire. the switch itself could have gone bad. went on mine.
Old 06-28-2007, 10:00 AM
BAD2000TA's Avatar
Yep, power window switch is very common to go out. Pull it out and test it. Replace if needed - they're cheap. Also, try this link for wiring info:
http://www.firebirdtransamparts.com/...ss/harness.htm
Really good info for researching your car. Good luck!
Old 06-28-2007, 10:02 AM
BAD2000TA's Avatar
Look at my own link ( ), there IS a Power Window relay. Might be that, too.
Old 06-28-2007, 08:48 PM
LOL no fellas the switch is out of it. im in the process of rebuilding her (almost done) and the power wire must have shorted out against the seat belt.
Old 07-15-2007, 08:02 AM
toplessHO's Avatar
I have a switch if you need one.
Dont know how its in the GM box but I can see
that the harness plug has been plugged into it.
Quick Reply: 78 t/a power windows question
