Starter i think? HELP!
Old 06-27-2007, 09:38 PM
mattraypharbor's Avatar
Default Starter i think? HELP!
sooo When i shut the car off theres all these horable clunking noises coming from where the starter is also when the car starts(during cranking) you can FAINTLY hear the noise but the car does start and runs vary well. It only does it if the car is about to stall or if i turn the car off any ideas?
Old 06-27-2007, 09:52 PM
anyone!!!
Old 06-28-2007, 01:59 AM
staringback05's Avatar
check your flexplate also....and make sure the noise is coming from where you say it is...usually a starter will make a different type of sound then a "clunk'
Old 06-28-2007, 07:32 AM
thanks will do.
Old 06-28-2007, 07:35 AM
anyone else have a similair experiance?
Old 06-28-2007, 11:50 AM
waldershrek's Avatar
check your flywheel bolts as well as your starter gear and make sure it is retracting all the way
Old 06-28-2007, 03:30 PM
OK i got it figured out. My tq converter bolts where lose and was causing the clunking. ALL is well now thanks for your help.
