Steering wheel play
Old 06-29-2007, 09:12 AM
BrentHamm's Avatar
Default Steering wheel play
The Steering wheel on my 98 Trans Am has alot of play? in it.
What i mean is when parked (or driving) i can move the steering wheel up and down 1/4" or so. I am guessing something is worn out, but not sure.
Any ideas?
Thanks!
Old 06-29-2007, 09:38 AM
rd_ls1_z's Avatar
If the car is still responsive, it might (just sonething to look at) be the tilt column mechanics. My steering wheel/column moves a bit too...
Old 06-29-2007, 10:57 AM
BrentHamm's Avatar
Everything else seems fine. And its not really a big deal..just wondering if there was an easy fix..i might do it.
Old 06-29-2007, 11:11 AM
rd_ls1_z's Avatar
Not sure how easy of a fix, or if it is fixable, but there should be a little play from the tilt just because of the mechanics of the gears or tabs for the adjustments. I only occationally notice my wheel move around, usually when I lean up in my seat is when I notice any play in the tilt.
Old 06-29-2007, 11:21 AM
BrentHamm's Avatar
Maybe its normal...will post a clip showing what i mean.
But.....my van (yes...van) does not have any play...nor my old bonneville beater (1994)
Old 06-29-2007, 01:31 PM
rd_ls1_z's Avatar
Video would be good, easier to see what you mean.
