D@MN STUPID F*#& PLUG!!!!! :cry:
Ok, I just had a bung plug put in my Y-pipe a week ago for my WB. I went to pull out the plug in the bung to install the 02 WB sensor and the G&D D@MN PLUG WONT COME OUT! I broke an allen, a pipe wrench, and a pair of vicegrips! I figure that after the bung was welded in and the plug installed, the heat from the welding sealed the plug in.
I have tried a propane torch and heated it for 20 min hit it with another pipe wrench and still nothing. Any ideas on how to get this out?
LS1TECH Sponsor
Same on the hex head. I welded my bung on with the plug installed with anti-sieze while I welded. No problems backing out after letting it cool. No problems getting O2 sensors in. I also tacked it on 4 sides first before finish welding all the way around.Good luck with it.
