ses codes after cam
ses codes after cam
Ok I have just put in the MS4 cam.
I have a Mail in tune
Now my car's running really rich and drinking up gas really bad.
SES lights that are coming on are...
P0101- MAF
P0121- TP insufficent Activity
P0155- O2 Bank 2 Sensor 1
If I'm driving around at 2,000 the car will cut out but just for a split second and, its not very often.
All my GROUNDS are good I have tested all of my wiring harness and it's good also. I have cleaned my MAF and Throttle body. I have cleaned all the connections also
What could it be?
What else should I do?
P0101- MAF
What could it be?
im pretty much 99.9% sure that these-
are tuning issues. for an ms4 i would say you really need someone to log and make the changes. on the maf it could be a small leak between maf and intake. i had those code a while back and it was air going in trough egr seal
thanks.
I have been telling the tuners that I thought something wasn't right with the tune but they have been making me check everything else so far.
What would be a good way to check for leaks?
i found it by wiggle test, just shaking everything in my last moments of desperation. then i heard the hissing sound from the rubber on the egr. one last thing you could do swap maf with someone else to c if it will clear. r u sure the a seal didnt fall off from somewhere, like the tb?
Ok another thing the ses light will come on, then just go away, then when it comes on the second time it stays. Well this time it came on went away came on went away then came on and now its stayed on.
to make it do this I have to clear the code with a scaner or unhook the bat. and the computer to clear the code.
I have the torquer 2 and mine does the same thing. A split hesitation and goes away. My ses light is on for both 02's. replaced them and it went off for a little while and now it's back on. I'm just gonna try to get a dyno tune and try to get it close to perfect. I'm hopin a real tune helps so i'll let ya know when i get it done.
