Need some Help, Car is acting up(sometimes)
I need some help diagnosing this issue:
Most of the time I will go out to my car start it up and drive it perfectly fine with no issues. But lately its been acting up alot! I believe it happening most of the time when its hot(no so much when cold). When it has the problem the car will not want to start at all, it wont idle, its missing and knocking. I can keep the car running by giving it some throttle, but it still will knock and miss horribly. Also I noticed when it was giving me problems my battery was at a really low charge on my voltage gauge in the dash, this could of been from the bad idle but maybe it has to do with something else?
So now comes the hard part..What the hell is wrong with it? At first I though it was a ground wire issue, I checked all the wires and made sure they were all secured. What else should I look at?
Thanks in advance
Thanks in advance
It only started to throw a code when the car started missing(which its suppose to do), Ill check the charging system tonight. Fuel pressure I will also check again(last time i checked it was good)
