T56 Clutch and Flywheel question
I bought a LS1 without clutch. Then i bought a T56 and the guy gave me flywheel and stock clutch off a car with 35k miles. The flywheel on the LS1 has 90k miles. Ive read that i should use same flywheel clutch combo cause of pattern on the surface. does the older flywheel look bad to you guys.
