McLeod slave cylinder with OZ700?
Old 07-05-2007, 09:52 AM
marlowchris's Avatar
Default McLeod slave cylinder with OZ700?
Is anyone using a McLeod aftermarket slave cylinder/throw-out bearing? The pictures on the website look like a real heavy duty unit. I am about to replace my Exedy twin with a TEX OZ700 and wonder if I should just stick with the C5Z06 slave or upgrade. An adjustable slave would be nice , so you could set the preload on the throw out bearing. BTW this is on a 02 Vette.
Thoughts, anyone?
Thanks
Chris
Old 07-05-2007, 11:17 AM
2QUIK4U's Avatar
Textralia recomends the use of stock hydraulics only. I already had the Mcleod adjustable master on my car and had to switch it out for a stock GM one when I put the OZ700 in.
