for sale: Hypertech Power Programmer
HyperTech Power Programmer for a 2000 LS1 Camaro/Firebird LS1/350 V8 - $140
It has been set back to original settings so your vehicle will be able to be used. This will only work on the above mentioned. Can be used with an Automatic or Manual Transmission.
If your looking for increasing horsepower and torque it's as simple as pushing a button with Hypertech's Power Programmer, You simply plug the Power Programmer into the underdash diagnostic port, answer a series of "Yes/No" questions, and the Power Programmer does the rest. The Power Programmer is much more than a tuning chip - it is a self-contained automotive tuning computer.
When you connect the Power Programmer to your vehicle, its "smart" program instantly recognized your vehicle's power train by reading its Vehicle Identification Number (VIN). The VIN contains specific information on the engine, transmission, and drive train, which the Power Programmer decodes before it downloads the Power Tuning program that is precisely tailored to your car or truck. The Power Programmer lets you choose Hypertech's Power Tuning program for regular 87 octane or premium 93 octane gasoline. Both options improve performance without detonation. After the tuning program is selected, the Programmer automatically installs the tuning program, and allows you to access and reprogram the vehicle's computer to function properly with aftermarket components such as non-stock tire sizes and rear-end gear ratios.
The Power Programmer is incredibly powerful, and it is also surprisngly easy to use. Reprogramming does not require any tools or knowledge of cars or even computers - plus you can return to OEM stock programming in just minutes.
Hypertech Power Tuning tunes your engine for maximum power and performance.
Dual Fuel Tuning lets you optimize performance for 87 or 93 octane gasoline.
Engine Rev Limiters extend your vehicle's RPM range for a wider power band.
Cooling Fan On/Off Temperatures permits the use of low-temperature thermostats for cooler, denser intake charge and lower engine operating temperature.
Transmission Shift Points optimize shift points by speed and RPM for maximum acceleration.
Transmission Shift Firmness give firmer full-throttle gear changes for faster acceleration.
Top-Speed Limiters allow the vehicle's top speed to be matched to the speed rating of high-performance tires.
Speedometer/Odometer Corrections correct speedometer and odometer readings for non-stock tire sizes and/or non-stock rear-end gear ratios.
Turbo Boost Pressure Control allows you to adjust your boost pressure.
