How to adjust non-TCS cruise control cable?
Old 07-08-2007, 02:12 AM
DuronClocker's Avatar
Default How to adjust non-TCS cruise control cable?
I got rid of my TCS/ABS systems and bought the correct cruise cable for the non-TCS cars. There's an adjustment on the end of the cable that appears to be like an older GM TV cable adjustment.
For the life of me, I can't figure out how to adjust it. Do I need to push the white square in, or pry it out to allow the sleeve to slide? I'm going on a trip tomorrow and would be very happy if my cruise control was working properly again.
Old 07-08-2007, 02:23 AM
:doh: Nevermind figured it out. Just have to pry the white square out slightly with the screwdriver and its spring loaded to self adjust once you slip it on the throttle body. Then push the white plastic square back into place and all is adjusted
Old 07-09-2007, 12:46 AM
2002_Z28_Six_Speed's Avatar
Hey, man. What was the code on your cruise control box? I got a couple different boxes with different codes on them.
Glad to see you got the TCS deleted out.
Quick Reply: How to adjust non-TCS cruise control cable?
