What is the largest ETstreet for a stock 16" Z-28?
After spinning my 315 Nittos like I was on ice through 1st AND 2nd on saturday, I decided to try some ET streets mounted on my old stock Z-28 rims. What is the largest ET street I can put on these rims? Also , Iv'e been told that you shouldn't have radials on the front while running ETs on the back. Has anyone ever done this?
Re: What is the largest ETstreet for a stock 16
You can only run 26x11.5x16 or 26x10.5x16 ET Streets. The 10.5 are closer to the OEM tire diameter, then the 11.5 ... plus the 11.5 grow as speed increases. I have run radials on the front with my ET Streets and no problems at all.
