baseline STS kit on stock motor, What cam? and fuel pump. power numbers and boost?
Old 07-10-2007, 09:34 PM
Function>Form's Avatar
Default baseline STS kit on stock motor, What cam? and fuel pump. power numbers and boost?
would the stock ls6 cam be a good turbo cam? also what fuel pump would i need to run 42# injectors and a baseline sts with a 60-1.
what boost is normally ran ~5lbs? what can i expect power wise?
Old 07-10-2007, 10:24 PM
trtturbo's Avatar
The LS6 cam works great.
A Walbro 255lph pump and 42's will do great with the turbo.
At 5psi, you should see around 100rwhp gain.
Old 07-10-2007, 11:26 PM
99Z28LS1's Avatar
and what makes you so knowledgeable on rear turbo's.........
if i were you, i would get their ^ cam, it works NICE
Old 07-11-2007, 12:30 PM
whitedevilWS6's Avatar
i'm thinking i'm gonna go with the 67mm, it's only 400 bucks more. even a stock ls1 cam should be fine with just the base 60mm sts. and i think sts can set you up with a methanol injection kit for about 500 bucks. good idea on stock internals. 99Z28LS1, i found some 61# injectors for cheap, even if i was only running 5-9 psi, think they'd be fine? i should have 6.0L heads on by the time i have my turbo set up but i don't know if i'll need meth injection or not.
Old 07-11-2007, 09:41 PM
WS6Vixen's Avatar
61# injectors? I know where to get 60# injectors, but where do you get 61#ers?
Anyway, before I put my new engine in my car I was running a completely stock LS1. I had the Racetronix Walbro fuel pump, 42# injectors and a T67. I got 467hp/508tq at the wheels on 7lbs of boost. I could have done 8lbs of boost and still had a reliable car. Anything over 8lbs on a stock motor really is too much if you want to keep it running. And unless you're going for something bigger than a stock LS1, you really don't need anything bigger than a 42# injector.
Old 07-12-2007, 12:18 AM
99Z28LS1's Avatar
60 pounders might be too much UNLESS you have plans on going further in your quest for more power. with 5.5-6psi on a stock clutch and header leak, i made 503rwhp and 512tq with TRT's cam
Quick Reply: baseline STS kit on stock motor, What cam? and fuel pump. power numbers and boost?
