Bearings for an offset crank?
I have an LS1 with an offset crank, going from a 3.62 stroke to a 3.70 stroke. I believe the journals are 1.888". The rods are Lunati ProMods. I am going to be moving all of the internals to a new block, need to get new bearings. Would any bearing that is made for a 1.888 journal work or is there something specific to the LS1 crank? I will be purchasing quality bearings. I would ask the shop that built the motor, I believe they are no longer in business. I tried the search, didn't find anything relavent.
I think the 1.888 is the standard honda bearing size, should I find something for that application?
Anyone?
I'd hate to have to use the existing bearings, even though they don't have much milage on them. I tried to find the build sheet for the motor, it is nowhere to be found. That probably won't have the info I am looking for.
Thanks,
Coop
Thanks,
Coop
https://ls1tech.com/forums/showpost....21&postcount=8
A later post suggests Aurora and Honda B18C series bearings.
