Hi Tech cam
Old 07-12-2007, 09:01 AM
INDIGO 5.3's Avatar
Exclamation Hi Tech cam
https://www.hitechmotorsport.com/sto...cb7ca7a8eaaf3d
Anyone ever run that one in their ls1/ls2? How did you like it?
Old 07-12-2007, 09:27 AM
Stang's Bane's Avatar
It is just a reverse split cam. Should work pretty well if you have a pretty good exhaust system and an average intake system. Depending on your mods, a standard split may work better or even a single pattern. The whole thing is a combination.
Old 07-12-2007, 09:36 AM
INDIGO 5.3's Avatar
My mods will be:SLP underdrive pulley, 160 stat, 3200 stall fuddle, volant intake, kooks 1 3/4 LTs with 3" catted mid pipes, dual 3" custom Magnaflow exhaust. Near future mods will be:FAST intake and have my stock 243 heads ported along with the FAST intake.
This will all be on an LS2 GTO A4.
Old 07-12-2007, 06:22 PM
TA455's Avatar
There's a guy on the GTO forums that apparently isn't too happy with it in his LS1. http://ls1gto.com/forums/showpost.ph...50&postcount=9
Personally, I have no first hand knowledge of the cam. It was just coincidence that I happened to see his post about the same cam you mentioned.
Old 07-12-2007, 06:28 PM
INDIGO 5.3's Avatar
Thumbs up
Thanks bro
Old 07-12-2007, 06:37 PM
speeddemongto's Avatar
those are wacky specs,I would stay away
Old 07-12-2007, 06:49 PM
INDIGO 5.3's Avatar
Yep, definitely disregarding that one.
Quick Reply: Hi Tech cam
