Is it ok to grind a little off the torque arm for exhaust clearance??
Old 07-12-2007, 11:33 PM
Raise's Avatar
Default Is it ok to grind a little off the torque arm for exhaust clearance??
Im installing TSP true duals next week. I can remember from my last car that the TSP system sits really close to the stock torque arm. Is it ok to grind a little off the torque arm so I can tuck the exhaust up a little higher?
Old 07-13-2007, 04:58 PM
OldeSkool's Avatar
is it a stock torque arm?
You might be able to get away with it, but you'll probably be grinding a pinch weld or a fold or something in which case you might want to have it welded after you make the grind.
I make no promises it won't ever fail, but neither does GM
Old 07-13-2007, 11:54 PM
ErikElvis's Avatar
Yeah a lil grinding prob wont hurt. Just Dont be stupid and grind excessively around areas like oldeskool said. Even if it does bend or break go aftermarket!
Old 07-14-2007, 01:50 AM
shoemike's Avatar
on stock you can maybe use a hammer and just dent it a little instead of grinding.
