What Air Filter?
What Air Filter?
I had my car tuned with a semi-dirty K&N filter in it.... I recently cleaned it and now it's all bent outa shape and impossible to go back... plus i never really liked the seal... what should i replace it with... I dont wanna go paper because I had it tuned with the K&N.
I thought maybe Fram Air Hogs?
or maybe the Accel Cool Blue (which i cannot find)
ANy other suggestions? anyone know any synthetic filters?
am i gonna have to get my car re-tuned if i go away from K&N?
Tuned with a K&N filter, huh? It won't make a difference if you go to a paper filter, you're not going to lose all 50rwhp that K&N filter promised to deliver. :sarcasm: I'd get a quality paper filter (Wix, Fram, etc.) and call it a day. No need to oil, no need to clean, no need to worry about oil on your MAF screen. (Hey, that ryhmes ) Plus, don't you need an extra seal for the K&N filter to seal properly?
If you're dead set on getting a re-useable filter, I used to have a Holley powershot filter on my car and it sealed great.
Everyone has there opinions, Ive run paper and K&N filters and Holley filters, THERE ALL THE SAME, Just pick one and go with it. And the filter wont make a difference on your tune, and this has been discussed over a 98453495858342025 Times already and nobody gets anywhere except an endless debate
From my experience using oiled air filters, with testing confirmed by oil analysis, they require very regular cleaning which quickly degrades the already poor filtering qualities of these filters.
The jury is still out, but it looks like the Amsoil EaA or EaAU are the ticket to efficient filtering and good flow.
ok... i dont really care about the difference between the air filters... lol as long as I can use any one with my tune... by banging my K&N on the ground it got all contorted and now it wont go back so it'll be getting a new one.... I did however hear of some synthetic filters that you can use that are like paper but provide more air flow and less particles... anyone hear of those?
Check out S&B filters. They do not require any additional foam or material to seal correctly like K&N. They also filter more efficiently.
http://www.sbfilters.net/index.php
See here for infomation on these filters. They also offer this same media in cone type replacement filters here
I've been using an AEM dry flo filter in my truck. They look like the K&N, but they don't take any oil. You just rinse them in a water-like solution once they get dirty. Not sure if they make them for our cars, I will have to check.
Anyone know the verdict on them?
edit: just checked, looks like they don't have one for f-bodies yet.
Originally Posted by 405HP_Z06
The filter will make a difference. Oiled air filters have a tendency to load up very quickly and cause a restriction in the intake tract. This restriction will cause the tune to 'appear' off. This results in pretty severe fuel contamination in the oil that will quickly cause detrimental wear on an engine.
