Is The Spec Stage 3 Clutch Kit Good For Daily Driving??
Old 07-17-2007, 06:23 PM
95transamlt1's Avatar
Default Is The Spec Stage 3 Clutch Kit Good For Daily Driving??
I am getting my spec stage 3 clutch kit with new slave and master cylinger from gm for an 02 trans am with my stock flywheel just re surfaced and i was wondering if this is a good set up for mostly daily driving and occassional racing at the track. Please post your opinions thanks guys . Also i wanna get a hurst billit plus shifter will that work good with my set up cause sometimes i have trouble from second gear to third
Old 07-17-2007, 07:26 PM
brad8266's Avatar
id go for a 3+ for a daily driver
Old 07-17-2007, 08:06 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
do u live where there is alot of stop and go traffic?do u have a long driveway?will said clutch be ridden/slipped alot?if yes id go 3+
Old 07-17-2007, 08:08 PM
Asmodeus's Avatar
The spec 3 is a puck style clutch.. it HATES daily driving and most of the spec 3 complaints are from people with daily drivers. You CANNOT slip or ride this clutch or it WILL go out on you very quickly. That said, I have a spec 3 in mine.. but I am very conscious about not slipping it. The tires bark at every stop light and stop sign, because you HAVE to let the clutch out that fast.. you CANNOT roll into first riding this clutch. It will hold up very well at the track.
Old 07-17-2007, 08:43 PM
ddnspider's Avatar
ROFLMAO.....i had a stage 3 in my old setup that was DD'd and slipped it all the time no issues.but from here on out i go under the assumption the person isnt a great driver and makes it easy for them with less complaints.YES u can use a stage 3 for a DD car without barking the tires,i never had that issues.but it was more effort and a 3+ should be easier.
Old 07-17-2007, 10:48 PM
Disturbed Bird's Avatar
i had a spec 3 and i dd in alot of traffic it went out in 5000 miles and it never saw any rpm drops or the track and chattered alot. then went to spec 3+ and is a world of difference and for the people that say its b/c i didnt set it up right i did. i had it sent to a machinest and installed by NLP. go with the 3+
Old 07-18-2007, 05:51 PM
bradl1982's Avatar
I have a spec 3 in my daily driver and have had it in there for about 25K miles. It's pretty easy to drive. I can take off just fine without too much chatter or barking the tires. It did take some getting used to though. They didn't have the 3+ when I bought mine but if I had it to do over again now I would go 3+.
Old 07-18-2007, 05:54 PM
u lose's Avatar
i'm driving the spec 4f without any problems.. not my DD but i drive it a decent amount right now.. little chatter if you rev it to 1300 or more and let it out..
Old 07-18-2007, 06:11 PM
nobreaks254's Avatar
wouldnt the LS7 be a better choice? Can you use the LS1 flywheel with the LS7?
Old 07-18-2007, 07:14 PM
no you have to use the ls2 fly
Old 07-19-2007, 10:27 PM
Krab's Avatar
You can daily drive a spec 3 clutch, but will you be able to put up with it? It all depends on your tolerance level. I don't find it that bad...
Old 07-20-2007, 04:19 PM
trey04gto's Avatar
I have it in my GTO and DD. It may hold good, but I cant wait to get rid of it. chatters like crazy!!!
Quick Reply: Is The Spec Stage 3 Clutch Kit Good For Daily Driving??
