CAM advice
CAM advice
hey guys i have 2000 mode T/A A4 i wanna install a 224/232 581/595 114 comp cam what do i need more ?
do i need 918 springs + lifters +a cooler for the trany to handle the cam
btw i have just istalled flat diamond pistons .
and if u have any thoughts about another cam im all ears
thanx
thanx
im looking at similar cams to make good solid power on the streets with my 99 A4...i think those are decent specs for the cam...I was also looking at cams in the 228/230 range they have a little more int. Anyways, you may want to consider buying a 3400 stall converter or so for your A4, you will feel a huge difference over the stock converter...this will help jack the rpms when needed to where your cam will operate at its best, rather than at the lower RPMs while still maintaining great street driveability.
Definately get a stall first...or at least along with your cam. Best desicion i ever made. And dont let people get to you with all that "cant drive with a high stall on the street" crap. I have a 3800 in my car and its 100% streetable. Car feels totally different now....but in a good way. GOOD LUCK!
