1988 GTA intermittant miss
Old 07-21-2007, 07:48 PM
george88gta's Avatar
Default 1988 GTA intermittant miss
Been fighting this issue for quite a while now. Entire ignition has been changed ( several times). Today I put one of those inline spark indicators ( neon light) in the coil to distributor wire. Car would barely run. Is this an indication that I still have a weak spark or is this not a valid test?
Old 07-23-2007, 01:44 PM
formul8's Avatar
Try replacing the module in the distributor and making sure the spark plug wires are not arcing by revving the motor in the dark and looking for sparks.
Old 07-23-2007, 02:21 PM
I have a new AC Delco module on the way. I checked the wires ( MSD) no arcing and I misted them with water and no change. If its not the module, I am thinking fuel or the MAF.
Old 07-23-2007, 05:53 PM
TTOP350's Avatar
It could be the dist shaft also. I have had to replace many of them..
Old 07-24-2007, 07:01 AM
Thats a possibility. I replaced the distributor once before. The original engine never recieved proper oil changing and the distributor was actually binding. There doesnt seem to be a lot of movement when I try to manually turn the rotor (dist installed).
Old 07-24-2007, 09:47 AM
blade2222's Avatar
weak coil?
Old 07-24-2007, 09:49 AM
Originally Posted by blade2222
weak coil?
Brand new AC Delco coil.
Quick Reply: 1988 GTA intermittant miss
